I am using Index and not importing my files into DTPO. I understand from the manual (p 46) that update indexed items will bring any updated/changed file attributes from the file that is still outside DTPO, into the DTPO index.
I am less clear on if this is a two way sync or a one way sync. Meaning, if I work on a file in DTPO and I remove or add tags to that file, what happens to the original file? Does it remain unaffected? Does it also get changed tags? Does it update when I update indexed items again - or will that completely nullify my having already changed the DTPO indexed version as it replaces the indexed item with the old info on the file on my hard drive?
Perhaps I am making this all more complex than it needs to be. Perhaps all the indexed files are actual alias style file paths and what I change in DTPO will also and always, affect the original file?
I would appreciate a little clarification on this.
Thanks
