Hi! Is it possible to define group-specific columns in list view? I know you can have individual sorting per group if you select the group in the side bar and then modify the group-specific sort order in the list view. But I would really like to have different column sets for different groups where different metadata fields are of interest. This should be preserved on an individual group level. Alternatively, if this is not possible, it would be great to have the possibility to quickly change between different column layouts in list view. Thank you!
Probably not what you want. I have different columns (metadata) for widescreen and standard view. If that’s not enough to see everything, I switch to full screen.
So, I can see just this:
or this:
