Hello,
I’m using the web clipper and it’s working fine, but I’d like to have access to the URL when I’m accessing the rtf on other devices (indexed to Dropbox).
To achieve that, I’d like to insert the documents ‘URL’ (ie: google.com) into the note body.
Something like this:
http://google.com
Clipped content here
It would be handy to do this with a script. It’s no big deal for it to be a second step to the web clipping. Any ideas?
This script inserts the URL into multiple selected text or RTF(D) documents. 3-pane, split or columns view is required:
set theWindow to think window 1
copy the selection of theWindow to theSelection
if type of theRecord is rtf or type of theRecord is rtfd or type of theRecord is txt then
set theURL to URL of theRecord
if theURL is not "" then
set the selection of theWindow to {theRecord}
tell text of theWindow
make new paragraph with data (theURL & return & return) at beginning
tell theWindow to save without asking
In this case the displayed (rich) text (“tell text of theWindow”) is scripted and therefore icon/list views aren’t supported. Another issue in this case is that the script modifies the selection and therefore document windows aren’t supported either.
