interface
I think the relation beetwen sets and the search window should be more transparent. Only after I had read a message in this forum explaining how tu use devonagent, I understood how to search using sets. Why not a drop down menu in the search window where is writen “Sets”?
Devonagent is great, but it takes a lot of time to learn how tou use it.
best
Roberto
Hmm, the search set pop-up menu actually says “Search Sets” on the top when you open it. And that it is a pop-up menu should be clear as the loupe symbol with the triangle is a standard Apple symbol used also in iTunes, the Finder, etc.
Best,
Eric.
