It did not. I am getting the same issue as @SlickSlack where any search just brings back a list from shortcuts, where the same search terms brings only 1 file from within DTTG.
You’re right, for Shortcuts the quick search method wasn’t used to name searches. Version 3.6.3 will this.
Great!
Is there another shortcut method that is working you recommend to try? I just want to make a note with date, and if already exists to append it. Should be easy with if statements but need a way to search and find the note. If not, happy to wait until update as it seems like this will be an option.
Hmm, searching for the document would also be what I’d do. Let’s try with the next release.
