OK, I see the same in Script Debugger’s result pane:
Scrolling down:
@cgrunenberg any idea what’s going on? Maybe DEVONthink and Script Debugger using an older WebKit version? In Safari the page displays fine
Scrolling down:
Seems Apple changed the Developer site again.
It’s now possible again to view Apple Developer bookmarks in DEVONthink (on macOS Mojave)
Hi, I’m not sure this is the right place but didn’t want to start another thread…
I’ve been having intermittent problems capturing web pages as PDF (using different settings) as DT3 captures the website as a bookmark, not pdf.
if I reboot my Mac, and try again, it seems to work.
not sure why this is happening…
macOS v11.6, M1 MacBook Pro DT3 3.7.2
workflow, browse web → use safari clip to DT3 extension (selecting paginated PDF usually, sometimes ‘uncluttered’) → web page captured as bookmark!
If I try using the sorter, I get the same result…
any ideas?
Joe
Yes, that currently seems to be the only option that works.
AFAIK the next release will make rebooting unnecessary (as it will restart those things that cause the problem automatically, I think).
thanks Pete31
The next release will automatically restart its background process for capturing, a reboot shouldn’t be necessary anymore.
