Is it possible to send the preview pane to a second monitor?
I’m finding it hard to work with the 3 column view on my 13 inch MacBook while triaging documents. In that view none of the columns are easily visible.
It would be very helpful if the preview could be seen on a second monitor while the first 2 columns remain on the first.
Any help would be appreciated. Thanks!
Welcome @Resserene
It’s not possible to split the view/edit pane from the main window. You could double-click the file to open it in a document window and move that window as needed.
Got it. Thanks.
You’re welcome.
This would be so good, and make it work with Sidecar as well please. Love DT but sometimes the screen of my 12" dosen’t let me use the full potential of the program.
