Hello, I am new to DTPro3. I find that I often change the name of documents to something written in the body. Is there any way to select text β change name to selected text ?
thank you !
Edit > Set Name As. Also available in contextual menus.
And also the shortcut Control-Command-I.
itβs the easiest for me. thanks very much.
And you could change the shortcut via System Preferences or CustomShortcuts app. The latter is much easier to use as it features auto completion.
