First, what do you call the numbers in the red box? And second, how do you access those, either in AppleScript or with a Smart Rule?
My goal, quite simply, is to create a “tag sweep” command that goes through various Databases and collects all these “empty tags” into a single “#Empty” tag. Or even just deletes them.
Also, is tag group something that only matters if you’ve got DT3 set to where Groups are also tags?
Thanks, I just found that. A slight variation: is there a way to do the same thing for Tags with exactly 1 entry? This is common due to some…err…mistakes made in the past.
I don’t use tags so I’ve no real experience but this should do it. Select all tags, run the script. It collects the children under one instance of a tag and moves empty tags to the trash.
Use a test database first!
-- Deduplicate Tags
set selectedTags to selection of think window 1
repeat with thisTag in selectedTags
set theGroup to create location (location of thisTag) & "/" & (name of thisTag) & "/" in current database
set theChildren to children of thisTag
repeat with thisChild in theChildren
move record thisChild from thisTag to theGroup
if (count of children of thisTag) = 0 then
move record thisTag to trash group of current database
Are you looking at the top level Tages group, or the Tags for a given database. They are not the same. The top level one is a union of all the Tags for all open databases.
If you are looking at the tags for one group, you can simply choose both groups and choose Tools > Merge.
One database, I have my tags currently set to not be unified. I forgot about the Merge command. Which brings me back around to my question re automation: can you automate merging and more importantly, can I programmatically access the number of items within a tag. I have TONS of “1 item” tags that are usually an accident or caused by importing RSS items or pictures (I’ve since turned off most automatic tag creation, though I’d like to be able to put it back on if I could easily maintain the tag database). Thanks!
Ah, thanks for the link. Basically the answer right now is “this can be done in a hacky way but there is no official support for it.” Your script looks helpful, but at the moment, the only thing I need to do is identify tags with just 1 item and I can more or less do that manually fairly quickly.
