I put all of my items into the Global Inbox. I tag them as to which of my 5 databases that they belong to. From each tag I move them by bulk into the inbox of that database. Is there a way to do that automatically?
From the individual database, can I do a similar process, except the end result would be one of the groups or subgroups inside that database?
Thanks for any help.
The following script moves the selected items to the desired databases, assuming that the first tag is identical to the name of the destination database:
set theTags to tags of theRecord
set theName to item 1 of theTags
set theDatabase to database named theName
if theDatabase is not missing value then move record theRecord to (incoming group of theDatabase)
