Greetings,
I’ve created a Smart Rule: it looks inside a specific group and excludes files with any of 3 tags.
The problem is: it still shows files with those tags.
What’s wrong?
I attach the screenshots.
Greetings,
What’s wrong?
Where? I believe I know why but you have not posted a screen capture showing the matches.
You need All of the following are true
Indeed, All is a better idea here. But I think there’s more to the story. However, only a screen capture will make that clear
Can you please detail your request?
I attach a screenshot here: is it enough?
Please note that all the files and groups are under the same Database, that is “3. Resources”.
In the rules I’ve selected “any” because I need to exclude files that have one of those tags (each file has one of them, as each tag refer to a stage of my content production workflow).
My goal for that Smart Group is: show all the files inside the group “00 Articoli drafts” that doesn’t have one of these 3 tags.
I doubt that.
You get confused by the negation. If you wanted a Smart Group that includes files which have any of the three tags you’d go for Any
. Any
is a logical Or: IF (tag A OR tag B OR tag 3). The condition is true if the file has at least one of the tags.
You want the opposite for your Smart Group: IF NOT (tag A OR tag B OR tag 3).
But the problem is that IF NOT… in DEVONthink’s Smart Rule nomenclature would be: Any of the following are not true
. Or in better English: None of the following are true
. But neither is an option.
That means the negation has to move into the bracket: IF (NOT tag A AND NOT tag B AND NOT tag C). The condition is only true if the file has none of the three tags. All
is the logical AND.
Short version: You need All of the following are true
It work, thank you very much!
Seems a bit counter intuitive for me, but it’s ok. I’ve learned something new about DT, that I appreciate more and more as I go deep.
If I remember correctly there had been a request for None
as a third option beside All
and Any
. Could have very well been my own request.
Very good translation of DT‘s „natural language“ to sound logic!
