Hi
I’m using a ScanSnap S510M and scanning straight into DT Pro Office 2.0pb4.
However, I have having the following issues with the settings in Preferences > Import:
When ‘Global inbox’ is set as the destination, nothing appears here but instead it goes into the selected database, but not in its inbox. Instead, it has to be found using ‘Today’ (and doesn’t appear in bold) and moved into the inbox. However, if ‘Global inbox’ is selected, the above works.
When ‘Select Group’ is set as the destination, similar behaviour occurs. The file ends up in the selected database and in no group, instead of the chosen destination.
The only working setting is ‘Inbox of current database’.
Also, when a document is moved from the Global Inbox into a database, it is copied and remains in the Global Inbox.
Kind regards
Nick
