I am using smart rules to move items out of my DT inbox based on tags, but after one of the smart rules has done its job the destination group contains a new subgroup named as the tag and what looks like a replicant of the item both inside and outside it (the original cannot be found anywhere else, so one has to be the original). What have I done wrong? I have copied another smart rule that does the same but for another tag and destination group, without any problem. The Database Properties are the same for the two destination groups. Please help!
I give a file a tag, which the smart rule is set to find, and the file ends up both in a new group named as the tag and in the folder that I set the smart rule to move it to. I want the smart rule to move whatever I give that particular tag (or name containing a particular word), also groups, but I do not want it to create groups with the same name as the tag and replicants of the item every time it moves a tagged item. How do I fix it?
P.S. The same problem has never occurred in the other smart rules that are fully analogous.
If you tag a file a replicant of the file will always be put in its appropriate tag group in the Tags group for the database. This is non-negotiable behavior and how tags work in DEVONthink.
Thanks for helping! However, what is happening is that the file moved by the smart rule to the destination group appears like a replicant there and a new group named as the tag is created in the destination group every time, containing what appears like a replicant of the file too. In other words, there is a long list of groups named after the same tag being produced. This is not happening in any of the other destination groups of analogous smart rules.
It is so strange. I only have two smart rules that I have made (plus only the built in filter duplicates and incoming scans). This problematic smart rule, and the analogous smart rule moving files into another group based on another tag (which works as it should). See screen shots.
Dear @BLUEFROG and @cgrunenberg
After having exhausted every possibility, I went back to basics and simply removed the smart rule with the problem and created the same rule again. However, this time I did not start by duplicating the analogous but unproblematic smart rule, but started from scratch. This time the smart rule works without creating weird groups with replicants, as described above. I just thought that info could be useful for you, as it could perhaps indicate that something is going on when duplicating smart rules.
The smart rules are not identical, the old one moved items having the tag kvitto or (!) whose name contained “kvitto”. Therefore the tag kvitto was most likely moved too and converted to a group and this caused the replicants.
