Hi,
All worked fine before but now, when a folder is selected, the contents in that folder do not appear in the detail box.
How can I have the the folder display its’ content?
The best,
-BrianP
Hi,
The best,
-BrianP
The right split view is almost at the top, therefore the contents aren’t visible. Just move the split view to the center again by dragging the navigation bar.
That worked! Thanks!
