I’ve notice an odd problem with Keyboard shortcuts for scripts.
Some scripts in DEVONthink’s script folder I have marked with a keyboard shortcut. Here an example:
In this example option-shift-O should trigger the Open Standard Databases script. And it does so when I have used DEVONthink for a bit, but it doesn;'t do so when I just have started up DEVONthink.
I think I need at least once have opened the Script Menu in the Menu Bar with the mouse, then the keyboard shortcut works.
The menu is only built/updated when necessary, one workaround is to add the shortcut to the filename (Open Standard Databases___Shift-Alt-O.scpt). But a script might be unnecessary in this case, you could also use a workspace to open all databases.
My script file is named Open Standard Databases___Shift-Alt-O.scpt.
Oooh, interesting! How can I reopen all my standard databases with a workspace? I searchED the DEVONthink help, but got no results.
(Background: I have to do this regularly, because my iMac is on a weak power circuit and here is winter, so the heaters draw sometimes too much power and than bumm! - Plus my UPS is still somewhere in a moving box…)
