Searching in the built in help function doesn’t show a list of keyboard shortcuts. It would be helpful, at least to me, if this were added.
OS X 10.9.4
DTP 2.7.6
OS X 10.9.4
DTP 2.7.6
DEVONthink and our other applications have a large number of keyboard shortcuts and most are easy to spot by going through the menus. There are just a few modifier keys (such as dragging with ⌘ and ⌥ held) and they are documented wherever they’re applicable.
Why would you want a list of all shortcuts that are listed in the menus?
This could be useful because it is sometimes difficult to remember exactly which menu a desired action is contained within, especially if it is infrequently used.
Dorich, you might find Keycue helpful.
+1 for KeyCue
