The label sort order doesn’t honor the sort order specified in the “Colors” preference panel.
In the Label’s preferences the sort order I’m expecting is what is set in the preferences from top to bottom:
“To Do” should sort before “Go”, which should sort before “Important”, etc… The sort order appears to be alphabetical by label name, which can change. The sort order shouldn’t change based on the current name of label.
