Legacy 'Print to Devonthink 3' command still on MacOS after updating to Devonthink 4 and removing Devonthink 3
Hi. My issue is outlined in the Topic. How might I remove this option in the Print options?
Thanks for any insights!
Eric.
Just remove the alias from the folder ~/Library/PDF Services in your home directory.
Thank you. That worked!
