Where is the correct location to keep DevonThink Pro Office script? The problem I have is that my scripts locations seem to be in a bit confused as comparing the two images below may indicate.
Fig 01 is of where I thought they were all kept; Fig 02 is those which actually apear in the DTPO script menu. Please note that there are no scripts whatsoever in the folder “DEVONthnk Pro”.
So really two questions, (1) Where should the scripts be?, and (2) Why do they not all show up when I am working in DTPO?
The location of DEVONthink Pro’s own Scripts menu is ~/Library/Application Support/DEVONthink Pro 2/Scripts, this is the recommended location. The location for the global script menu extra would be ~/Library/Scripts/DEVONthink Pro
I’m not sure whether you’d prefer to use DEVONthink Pro’s own Scripts menu or the global scripts menu extra.
The global scripts menu extra is tricky. The scripts of the folder ~/Library/Scripts/DEVONthink Pro are always accessible, the one of the folder ~/Library/Scripts/Applications/DEVONthink Pro only if DEVONthink Pro is the active application. Depending on your usage you might use one or the other.
