Login screens when saving linkedin and reddit posts
When I try to save a post from Linkedin or Reddit, whenever I save it in web/pdf, the resulting item in DT ends up having a login box/modal on it and I can’t see the specific content I was trying to save. If I save in markdown, it doesn’t pull the full post. Is there a trick or a workaround?
Welcome @cleckert
Try adding a bookmark to DEVONthink and logging in inside your database then clipping via the Tools > Capture commands or the action button (gear icon) in the Navigation bar over the view/edit pane.
At least with LinkedIn posts this works. I haven’t tried with reddit posts. You don’t need to login. You can just dismiss the login window and then Capture.
