DTPO complained of missing files when syncing, so I tried Verify & Repair a half dozen times. Apparently it doesn’t Repair, as the problem persisted. I rebuilt the databases, sync started again and took quite some time to finish on the last item. Finally it finished, but the sync errors persist (tail of log attached below). I’m starting to lose confidence in this system - can it be trusted with all the artifacts for my PhD?
- Why do these errors arise when I haven’t manipulated the files outside DTPO? (There have been no crashes, reboots, etc.)
- Why doesn’t Verify & Repair repair the errors?
- Why doesn’t Rebuild database… correct the errors?
- Why do we (users) see database errors? Modern databases maintain consistency themselves.
John
2:06:41 PM: ~/Documents/Bookends/Attachments/EndNote Attachments/Melzack1965Pain Mechanisms A New Theory.pdf No Text
2:06:51 PM: ~/Documents/Bookends/Attachments/EndNote Attachments/norman () attention to action. willed and auto.pdf No Text
2:06:52 PM: ~/Documents/Bookends/Attachments/EndNote Attachments/Oldfield-1971-The assessment and analysis of h.pdf No Text
2:07:39 PM: ~/Documents/Academic.dtBase2/Files.noindex/pdf/8/Degree.pdf No Text
2:07:39 PM: Importing 686 items
2:07:39 PM: Done.
2:35:09 PM: Sync: Inbox -> john@johnjohnson.info (Dropbox) The operation was cancelled.
2:35:09 PM: Sync: Inbox -> john@johnjohnson.info (Dropbox) Palmgren vise receipt: (Could not load a record (not found ({"error": "File has been deleted"})))
2:37:12 PM: Sync: Inbox -> john@johnjohnson.info (Dropbox) The operation was cancelled.
2:37:12 PM: Sync: Inbox -> john@johnjohnson.info (Dropbox) Arcs and Angles receipt: (Could not load a record (not found ({"error": "File has been deleted"})))
