Goal: I am trying to link from one markdown file to another, but for simplicity of typing and less distraction without the double brackets for Wikilinks.
Example:
- database with only two files, names file1.md and file2.md
- typing the word file1 inside of the file file2.md: file1 is shown as a link (blue & underlined) as expected.
What I am trying to do: getting rid of the brackets, but at the same time check for the name of potential links to other files. I thought this is possible via Option-Escape (Complete). This is indeed working as expected, but only IF I use “[[” as a start for the link and type a phrase. In the above example I get a list with only file1, as there is no other file in the database.
The help states:
Square Brackets: WikiLinked text can be defined using square brackets. Type two opening square brackets and the beginning of a document name. Then press ⌥⎋ Option-Escape to show a list of potential item matches in the database. Choose a document and press
Return to complete the link.
What irritates me is the result of Option-Escape without “[[” before the phrase: it is a fairly random list of (English) words without any relation to the (only) database I have open.
My two questions:
- Can I do intentional (choose from a list) Wikilinks without [[ ? If yes, how?
- What is Option-ESC doing when used on a line without [[?
