Hello DEVONthink team,
First of all, thank you for your great work on improving Markdown in 4.4 Tycho update!
I’d like to reference a couple of previous discussions here, here, and here regarding the RTL text alignment issues in Markdown documents.
Before, the RTL text would change back to LTR as soon as I typed one letter. You fixed this perfectly in version 4.4. But, there is still one problem, which is why I say we are “halfway there.”
Here is what happens:
Open a Markdown document and set: Format → Alignment → Writing Direction → Right to Left.
The text looks correct, and typing works great.
Click on another document, then go back to the first Markdown document.
The text direction changes back to the “Default” option (which is LTR).
Could you please make DEVONthink remember the RTL state per document (or offer a persistent setting)? Fixing this would make RTL Markdown editing perfect.
Thanks for your usual great support!
