Hi All,
Having a bit of a problem with some of the click and drag rules. I am trying to drag a jpg from inside devonthink onto the icon box of the info panel of a group (so as to change the appearance of the icon). So what I do is select that group, and bring up the info pane. I have the image i want to drag visible while still having that group selected (so it stays in the info pane. So i go to the image, and click and hold so as to move it to the icon in the info pane. But when I do, it selects and drag selects the item! (rather than moving it) So it unselects the group in the process and I lose the info pane for that group. This is really frustrating, just can’t seem to move the image into the icon section of the group info pane. What am I doing wrong? Thanks,
Jonathon
