How can I bring up the Navigation pane (with icons for Search, Library, etc)
The only window I see is the database window.
Navigation pane?
Hi, thanks for responding
not sure what to call it , I want to get to the view that give numerous
options for on-line search databases like Pubmed etc
this is what I mean: :: how do I get to this ??
support.mekentosj.com/kb/discove … -3-for-mac
I am sure it is really simple / obvious but I can’t find it (I saw it once)
thanks
JC
DEVONthink doesn’t support online searches.
thanks,
However the Papersapp Support site says it has built in search engines - and this site shows it
can you tell me how to get to the page in this link describing how to set it up ?
JC
That’s a third-party website & application, it’s not related to DEVONthink in any way. You have to use Papers to get that view
Ugh - Chrisitan - my apologies , confused the app’s
Bought DT also,
thanks for you patience ,
JC
