I have DTPO and created a database in it that is stored on my Mac, not in iCloud or Dropbox.
I just purchased DTTG so I can have my databases on my iPad and iPhone.
I would like to sync my databases using iCloud. Using Preferences on DTPO, I set up iCloud as a Location and selected a Database. It shows that it synced this morning but I don’t see it on my iCloud Drive.
Going to DTTG Settings, it shows iCloud as the sync Location with my database enabled. It shows a sync has occurred but no data is available. I noticed at the top of the Settings window, an alert that shows iCloud Property list invalid. What does this mean and how can I fix it?
In DEVONthink, hold the Option key and select Help > Report Bug. Also attach a screencapture of DEVONthink’s Preferences > Sync with the sync location selected. Thanks!
