I’ve disabled database option ‘Exclude Groups from Tagging’ so all groups become tags. I can disable the groups I don’t want to be used as tags by right-clicking on them, but this is slow process for the amount, I wanted to add a keyboard short-cut to this function via system preferences.
Having added one in the keyboard shortcuts on ‘Exclude from Tagging’, it doesn’t work. So I tried to locate this command in the dropdown menu to confirm the shortcut assignment worked, but I cannot find the command. It only appears to exist as a right-mouse-click on the selected folder, and I’m guessing this is why the shortcut isn’t working.
- Could you check and confirm it is not possible to as a keyboard shortcut to ‘Exclude from Tagging’
- Could you add this option to the command list (even if an option-key-menu-item) so I am then able to assign a shortcut to it.
Thanks.
