Strange event:
- I had been using Devonthink for days on and off.
- I discovered I could not edit some text files in Inbox.
- I stopped and restarted Devonthink (beta6 I think).
- The menubar widget appears, but no databases are listed.
- The Devonthink icon has the little dot below it showing it is running.
- No Devonthink window opens. Clicking on the icon or particular databses does not open a window.
- Activity monitor shows Devonthink running and using resources.
- Been waiting a half hour with no change. System seems to be running fine otherwise. I ran some system tests. Disks check out ok.
Any ideas?
Thanks,
Timothy
