Another issue I have since upgrading my MacBook is that I can no longer scan. DT lists the scanner under Devices and shows me the scanning interface including letting me select the various options (doc feeder, colour/bw etc), but when I click on “Scan” I get: “Could not complete the scan operation, error communicating with [printer/scanner name]”.
I’ve tried restarting, and scanning works fine from Image Capture.
Providing information about the scanner you’re using and how it is connected as well as the various software versions (“upgrading my Macbook” doesn’t tell us anything about the OS you’re using nor about the DT version) might make providing help smoother.
Sorry. It’s an HP M479fdw connected via ethernet to an M3 Max MacBook Pro.
macOS 14.1.1, DTP 3.9.4.
The only thing that has changed in the setup is the laptop (previously an M1 MBP), and any point updates to the software since I upgraded laptops less than a month ago.
