I’ve been using onenote and before that - evernote to take meeting notes. But I’ve recently moved to DTPO. So far so good.
A couple of questions though:
- Note titles:
Is there a way for DTPO to use the first line of my note as the file title. Currently it’s a two step process - create new note, title file, then type note.
Compare to evernote where you - create new note and type note, and the title is automatically grabbed from the first line of the note. It’s a small thing but just wondering.
2.if you double click on a note and open it to it’s own window, you can’t change the name easily.
- When creating a formatted note, is there a way to get a formatting tool bar to show up?
Any suggestions as to “note taking best practices” would be appreciated!
Thanks
