Since DTP 1.3.2, the OCRed docs are totally not readable, very fuzzy. Is there an adjustement to make?
Thanks.
Thanks.
Sounds like you are looking at only an icon of the first page, not the actual PDF file.
In such case, select the PDF and open its Info panel. Check the Path to the file. Where does it point? Is the file at that location?
You can also check the image quality parameters in the OCR preference pane of DT. There you can select the quality and resolution of the PDF image as of the new version.
That was the problem, now solved. Thanks.
