I highlighted about 18 PDF’s (all under 50 pages) and told DT to convert them. it did all but 5 of them and then stopped. I re-highlighted the remaining ones and asked it to convert, and nothing happened. I restarted DT and did it again, nothing. I cleaned system and user caches and repaired disk permissions. No change. I reinstalled DTpro office. Still nothing.
The one that I am having problems with (I’ve had problems with it before with the same issue) is a G5 powerPC running Tiger. My laptop which is doing the OCR fine is a new Macbook Pro running Leopard.
I have reported a bug to IRIS about a similar situation with them and we’re trying to find a solution with them, however I’d still like to have a sample document if you can provide us with one.
