OCR to searchable PDF creates two replicants
Is the option to exclude groups from tagging (see File > Database Properties) enabled (default) or disabled? Are you able to reproduce this?
Hi
The option to exclude groups from tagging (see File > Database Properties ) is enabled.
I can repeat this with the same file and other jpegs dragged from mail in the same way.
Thanks
Are you also able to reproduce this using a new database? Do you use the latest version 3.8.7?
Yes
Yes
And still no smart rules which are e.g. triggered on OCR, tagging or moving?
  • What does your smart rule look like?
  • How many smart rules are you running, especially those that may affect the same group?
The few smart rules I run are “on demand” and none involve OCR
then moved them to a group
What smart rule is running on the group in question?
None. They are moved “ by hand”. Dragged to the group they should be in.
Hold the Option key, and choose Help > Report Bug to start a support ticket and we’ll go from there.
