I have searched and read on how to import mail.app messages to DTpro. However, in my script menu, under MailScripts or under DevonThink Pro, there is no “add message to DevonTHink”. There are other scripts like “Copy Selection to Incoming” under DevonThink Pro script folder and others under the MailScripts folder.
I’ve downloaded the application several times and installed it. I’ve done the “Install add-ons” but the script just doesn’t come up.
I want to have most of my mail in DTpro so I can have them with the subject I’m working on.
I’ve done the “select the e-mail you want to import. Select All, and drag.” But I only get the headers with a Safari symbol on the bottom.
I’ve got the same problem. I tried the Deleting the Scripts Folder in Library, but there are no new scripts anywhere. Not in the ‘Addressbook and Mail’ folder, or the Import folder.
What’s in the folder ~/Library/Scripts/Applications/Mail? Note: The script menu is application specific, you have to switch to Mail before checking the menu.
