Open sorter with predefined options (ie specific format, location etc)
Hi all
i make heavy use of the sorter to capture webpages, quick texts, bookmarks, markdown etc…
this creates a lot of work (well you know in a 1st world problem sorta way :)) with needing to keep changing the specific format, location of each capture…
i started using omnifocus recently and it seems they have a lot of flexibility in using URL schemes to open the omnifocus capture window with pre defined options (tags, location etc)
So i was wondering, can we do something similar with sorter? That is suppose i know im about to capture a bookmark in a bookmark group, can i launch the sorter pre configured like that? Then maybe i can bind a key to each mode (via 3rd part apps such as keyboard maestro) which would make capture much faster…
any thoughts
thx in advance!
Z
You can set a destination parameter in our URL scheme but no you can’t pre-set the Sorter.
thx @BLUEFROG!
wondering what the community thinks of this and if anyone else would find something like this useful?
best
Z
I would be a heavy user of that possibility as well
@BLUEFROG, did you set the destination of the sorter or in general via the URL scheme?
thx
Z
It’s a parameter of the URL scheme. Nothing to do with the Sorter.
i see, would you mind @BLUEFROG to give one example of such a url i can test?
thx
Z
x-devonthink://createtext?title=testing&text=hello&destination=4485CC9B-2EDC-4B71-96E2-C6E2CAB7352E
Gotcha, perfect thx!
Z
