Option to _NOT_ index records
I looked but couldn’t find anything. Is there an option to NOT index the documents inserted into a database?
The Use Case would be the following: you use a database on a network share with lots and lots of documents into it. The documents are index-able by DEVONthink so they take a while to get added to the database, queries to the database take forever to complete… the database is slow. The only query of interest is the “search by name” query that DOESN’T require the indexing of the contents of the files.
Is there a way to do that right now? If not, it would be a really cool option to have in the Database Properties dialog box.
Thanks,
Pascal
That’s not possible but EasyFind might be an alternative (depending on the number of files and speed of the network volume)
