I have used DT since version one (currently DT Pro 4 Beta 3). I use it many times a day. My main use is to download web pages as paginated PDFS. For some reason, it seems to have stopped allowing me to do this. This is particularly true of Substack (which I use frequently) but also New York Times and other sites that I have used for years. I used to be able to convert pages if they only downloaded as URLs but this also no longer works. Any help greatly appreciated. I did try using reader view in Safari as suggested in a much earlier response to this problem but it doesn’t make any difference. Is this an interaction with Sequoia perhaps? Or a change in the practice of publishers? Either way it is limiting my core utility of DT Pro. Thanks for any help.
How exactly? Does rebooting the computer or restarting the app make a difference?
No unfortunately rebooting computer, rebooting DT, nothing makes a difference. Frequently there is a PDF but it is blank.
Paywalled sites can cause clipping issues, especially as they want to protect their content.
Are you using our browser extension or printing to PDF?
