I recently started using DEVONthink with the goal of keeping my PDFs organized - currently I imported approx. 600 into DEVONthink. In 1.7.4 all worked fine (all imported files are copied to the database directory just as I set it in the preferences). I then upgraded to 1.7.5 and moved the database out of "Application Support". While doing this my paths were messed up. Now, I only see the thumbnail of the PDFs not the PDFs themselves. I can manually correct the path using "Show info" but that would take forever.
Is there a way to re-set those paths from within DEVONthink via a menuitem? The filenames haven’t changed so it should be trivial to do so. Also, something like an integrity check showing unreferenced / missing files in the database folder would make sense IMHO.
Looking forward to a solution…
