Possibly related to the fact that I am using DT on two computers and trying to keep them synced (I posted about problems with that last week), I am occasionally getting the following:
With a PDF that is copied to the database folder, the PATH attribute gets corrupted, although the URL attribute still points correctly to the file in the local database.
For example, I have a record called Hansen 1999.pdf
The path has gotten corrupted somehow and now points to:
"/Developer/Documentation/Cocoa/Conceptual/DisplayWebContent/Concepts/WhyWebKit.html"
But the URL still points correctly to the file:
/Users/weeks/Library/Application Support/DEVONthink/Files/Hansen 1999.pdf
I can manually fix this in the Info window, but I wonder what is happening.
It seems random what the PATH will point to when corrupted. On another file, it points for example to:
/Library/Printers/EPSON/Help/Help_W/PrintSettingA.help/Contents/Resources/French.lproj/D4_07.HTM
Help!
John
