Bill. Okay thanks. It took me a minute to follow what you meant, but I got it. I can be slow.
Is there an actual folder that the file is sitting in in that case, or is it like an invisible folder in the program? The imported file doesn’t appear to be in any of my group folders. It just seems to hover in the ether where it can only be seen in the list when I click below the group folders. Ideally, I’d like to be able to access the folder directly if there is a way. This behavior only seems to occur in the 3 pane view btw.
Thank you for the command click hint. It will certainly help if there isn’t a way to view the folder directly.
