help for a script
Hi,
I have this script I done here some times ago:
activate
set destinationGroup to create location "/collocazione"
set scheda to create record with {name:"colloco", type:form} in destinationGroup
replicate record scheda to current group
this creates an record in a sheet called ‘collocazione’ and makes a replicate in current group. I’d like to add 3 things to improve it, but I’m not a programmer, I hope someone can help me.
1- the name of the record has not to be ‘colloco’, but the name of the actually selected object in devonthink
2- the replicated record has to be grouped with the current selected object in devonthink, using the same name
3- the record has to be opened to edit it
For example. I’m in devon and I select a pdf called ‘work2’. I start the script and after the script I’d like to have a group called ‘work2’, and inside the group the pdf ‘work2’, and a new replicate record called ‘work2’ opened for editing datas.
I hope someone can add this 3 things can help me (a lot) to archiviate datas. Thank you.
f.
Eh eh I have done it by myself!
activate
set destinationGroup to create location "/colloco"
if theSelection is {} then error "Please select some contents."
set firstItem to item 1 of theSelection
set current_name to the name of firstItem
set scheda to create record with {name:current_name, type:form} in destinationGroup
set theGroup to create record with {name:current_name, type:group} in current group
move record firstItem to theGroup
replicate record scheda to theGroup
open window for record scheda
Thanks for all the scripts I used for example.
This script can be useful waiting for 2,0.
- I create a sheet with all the fields I need for files I scan (origin, date, destination, et ceterae).
- After a import from scan, I select the pdf, activate the script and devon group the scanned document with a replicant of a new record with fields I need, and opens me a record for insert the info about origin, date, etceterae.
Every document is grouped with a record with all the info about it, and opening the ‘colloco’ sheet I have a complete list of the file scanned with info about every file.
I hope this can be useful for someone.
f.
