Hi, I’m writing a “hello world” plugin to search databasebasketball.com. You input a last name in the search query and it will either return a list of basketball players w/ that last name, or the player’s main page if only one is found. Here’s the XML:
What version of DEVONagent are you using? On the latest version (2.0.2) this works like you’d expect. When searching for Drexler, I get 7 documents. In the Digest I see a nice diagram when I click on the “Drexler” topic, in the Pages I see no “teams” in the URLs and in the Log I see that it initially got 41 links.
This is my list of results (now there are 8), as you can see there are no links with “teams” in them. And I just copied your plist description and stuck it in the app’s Plugins folder.
Clyde Drexler Stats, Statistics and Fantasy News - RotoWire.com
Drexler is considering a return from retirement and the Nuggets are high on his list of teams he’d like to play for the Denver…
[www.rotowire.com/basketball/player.htm?id=1428]
Ahh, I figured it out–it was in the ‘settings’ pane–‘follow links’ was on. I guess I assumed DA would use my LinksNotMatching criteria, but it seems that stuff is disregarded after the initial search engine results.
