Printing Problems in Devonthink 2.0
I’m trying to print a .doc file from Devonthink 2.0, but it only prints what is visible in Devonthink and not the whole document
How can I sort this out?
Thanks
Tim
You are most probably looking at the QuickLook preview. Open the document in the original application (Open With…) and print it from there. Or switch to the Text View but you may not get a good copy there either since it uses Apple’s conversion of Word documents.
Thanks - I’ll try that. If I don’t get back to you it has worked
