Probem with ^accent in french when using markdown
Hello,
I’m using a lot markdown to take notes in french ! So I do use a lot the ^ accent : ê and î and û and ô.
Unfortunately now when I use this accent it make an exposant. I join a screen capture to explain my problem ! It’s a little bit annoying because I have to spend some time correcting them.
Sorry for my english and thank you in advance for your advises.
Julien
This is a known issue which will be fixed by the upcoming version 4.4.2. In the meantime disabling WYSIWYG editing (see Format menu or Settings > Files > Markdown) should fix this too.
Thank you very much for those informations.
And yes it’s working again !
