Hi there, I frequently send mails whose only content is an URL to myself. With DEVONthink Pro I used Automator actions to search them and create PDFs. As I have to rebuild this workflow I also want to automate it further as those mails often contain URLs which have to be created via Safari’s print dialog.
When reading in Safari I already use a handler that automates “Save PDF to DEVONthink 3” to a specific DEVONthink group and it works fine.
In the script I’m working on I use another handler that checks if Safari has finished loading the page. However if I use the same “Save PDF to DEVONthink 3” handler I already use in Safari (via script library, so it’s really the same) in the new script it will create PDFs in DEVONthink 3 but they have no URLs.
If I use the print dialog manually the records have URLs. If I use the handler while reading in Safari they also have URLs. But they don’t have URLs when created with the new script.
I already tried to set delays and set them higher (many more delays and much higher as in the handlers below), but that didn’t help - and that doesn’t seem to be the problem as PDFs are created but without URLs.
Any ideas?
Here's a part of the script to test if you also get records without URLs
property theURL : ""
property theGroupName : ""
tell application "Safari"
make new document with properties {URL:theURL}
activate
delay 1
set pageFinishedLoading to my waitForSafariPageToLoad()
if pageFinishedLoading = true then
set printPDF to my printPDFToDEVONthink(theGroupName)
if printPDF = true then tell application "Safari" to close window 1
on waitForSafariPageToLoad()
activate application "Safari"
tell process "Safari"
set theReloadButton to ""
with timeout of 30 seconds
repeat until theReloadButton is not ""
repeat with i from 1 to 10
set theReloadButton to (first UI element of group i of toolbar 1 of window 1 whose name is "Diese Seite neu laden")
exit repeat
end timeout
if theReloadButton ≠ "" then
return true
else
return false
end waitForSafariPageToLoad
on printPDFToDEVONthink(theGroupName)
with timeout of 15 seconds
keystroke "p" using command down
repeat until button 1 of sheet 1 of window 1 exists
delay 0.5
#keystroke "p" using command down -- (shortcut for "Save PDF to DEVONthink 3")
click menu button 1 of sheet 1 of window 1
click menu item "Save PDF to DEVONthink 3" of menu 1 of menu button 1 of sheet 1 of window 1
tell process "DEVONthink 3"
repeat until pop up button 1 of window 1 exists
delay 0.5
set focused of text field 2 of window 1 to true
set value of text field 2 of window 1 to theGroupName
click button 3 of window 1
return true
end timeout
on error
return false
end printPDFToDEVONthink
In case of a PDF document directly printed to DEVONthink (or using services or drag & drop too), DEVONthink tries to retrieve the URL from the source application and sets it. But if a script is used to print to DEVONthink, you have to set the URL of the new record on your own.
Ok, but why does the handler work in a script I use with Keyboard Maestro? It’s the same script library and the same source application (Safari) but I get different results.
Just as an aside, UI scripting like this is fiddlly and easily subject to breaking. It’s a better idea to not try and reproduce physical movements, like button presses, except in very unusual circumstances. I would caution you to not become too reliant on it.
Setting the URL afterwards did the trick, thanks @cgrunenberg
-- Automating "Save PDF to DEVONthink 3" to specific group. It will save to the first matching group that DEVONthink finds.
property theURLs : {}
property theDatabaseName : ""
property theReloadButtonName : "Diese Seite neu laden" -- you get the name of your reload button if you hover long enough over it
repeat with thisURL in theURLs
make new document with properties {URL:thisURL}
activate
delay 1
set thisPagesURL to URL of current tab of window 1 -- get the the right URL even when redirected
close window 1
delay 1
set currDate to current date
set theComparisonDate to currDate - 300
set lastAddedRecord to item -1 of (search "additionDate >" & theComparisonDate in (root of database named theDatabaseName))
set URL of lastAddedRecord to thisPagesURL
set theReloadButton to (first UI element of group i of toolbar 1 of window 1 whose name is theReloadButtonName)
exit repeat
end timeout
return true
else
return false
delay 0.5
#keystroke "p" using command down -- (my shortcut for "Save PDF to DEVONthink 3")
delay 0.5
return true
end timeout
on error
return false
