Happy Father’s Day to any dads out there.
Hoping someone has an idea of what I’m doing wrong. I’ve set Hazel and Automator to do a simple rename with date, add a tag, run automator to import and place in DTPO, then trash original file. Everything works as expected except that upon import to DTPO, file is converted to txt. This occurs regardless of if the file is eml or pdf, etc. So I’m thinking I’m missing something or have set up the actions/sequences incorrectly. I’ve checked DTPO preferences/import but don’t see anything that would affect it and I don’t have any scripts attached to folders (at least none of which I’m aware). I’ve attached the Hazel and Automator info windows. Appreciate any suggestions.
