Problem when importing .csv file
Hi all
Is DEVONthink able to import .csv file? I tried several times but failed, nothing was imported to the inbox or any folder/group.
DEVONthink Pro (Office) fully supports this, in case of DEVONthink Personal the document should be imported but is displayed as plain text.
No, it does NOT import anything… I create an empty group to import some csv file, and it was always empty. I even tried to restart my Mac …
BTW, I updated my system to 10.14.3 Beta (18D39a), would that be the problem?
Is anything logged to Windows > Log?
Yes, the “File/Actions” is the path to the csv file, and the “Info” is “Failed”
Could you please zip the file and send the archive to cgrunenberg - at - devon-technologies.com? Then I could check this over here. Thanks!
Sure, I have already sent it. Please help to check it. Thanks!
