Three-way sync (desktop, laptop, iPhone) been working fine for weeks on my custom WebDAV server. I am syncing 2 different databases (plus the global inbox) with encryption.
After renewing the SSL certificate for my server, I get a strange error in DT: “Verification of uploaded item failed.”
- If I do “Verify location quickly”, I get “Location successfully verified”.
- In Preferences > Sync, I can see one of the databases, as well as the global Inbox, being successfully synchronized (the last sync time is right now).
- If I use “Clean Database” on the database generating the error, it is wiped from the server (“Not yet synchronized, upload database”). If I then uncheck and check the database’s tickbox, I again get “Verification of uploaded item failed.”
I have no idea which item is causing the problem and how to locate it, because it looks like this:
Obviously the WebDAV server is working because the other database is syncing as it should.
How can I fix this? I remember previously fixing this error by physically deleting the dtCloud file on the server but this is annoying to do every time just because a single file causes an error somewhere. Also, it requires all other devices to resync the entire database.
Thanks.
