When looking at any folders in DT, while using 3-pane-view, it feels like the list of items gets pushed up so much so the first few items are hidden under the top design element where the path is shown:
Big Sur 11.4 on MBP on M1 with DT running on 3.7.2.
As for app restart: it opens in list view and shows top items under the path element on top (so same wrong as 3-pane). If I then click on 3-pane, the problem persists. However, again clicking on list view shows the correct view with all items to be seen.
What is a second window? On a different monitor? Or in 3-pane-view the next window to the right of the list? If I am in 3-pane-view, the first window to the left is showing the wrong behaviour and the middle one as well.
A similar thing is when I open markdown files that are longer than what is shown they seem to center in a way that the top is slightly out of view.
What version of macOS? 11.4 like the original poster?
PS: I go through tons of support tickets every week and most people use a forum handle that’s not their real name, so cross-referencing between the forums and support tickets is often not easily done.
I should be more adventurous - I saw column view without realizing you can horizontally scroll. My new favorite mode - column view, hidden sidebar, and for a nice big picture of where I am, preview mode “none,” since you still get a preview if you scroll all the way to the right.
Regarding the bug, I see the same thing but can vertically scroll to see what’s under the toolbar. Could this be a problem with just the right number of elements, with just the right screen scaling? No scrolling, size just off by enough to mask some stuff?
Just a wild guess, being a little restless and trying to avoid real work. I’m a slacker…
I wonder whether it’s related to system preferences as columns view is my preferred view and I don’t experience this issue (same macOS version). A screenshot of System Preferences > General would be useful.
I think it does. I can’t reproduce my own error anymore. I had to remember to set everything back to column view (what I referred to as 3-pane-view wrongly), and it shows up always perfect, with the item at the top still viewable.
