Hello!
I have a template in my Library/Application Support/Devonthink Pro 2/Templates.noindex folder which is a Apple Pages document which I use for writing letters.
The idea is to create a new Pages document with the template, then do the modifications and then save it.
I have the problem that Pages will not save the modified version of the template. I have a workaround that is like this: copy the file to the desktop, delete the file inside of DT, modify the file on the desktop and then import it back to DT. But this seems very stupid.
Some time ago, my intended workflow actually worked, but sometime something went wrong, I guess it relates to some update which I did to OS X or DT.
Does anyone has some help to offer?
Thank you very much,
Gernot
